Coolant leak troubles need fast help
  • tatertots
    • 104
    So i have a 1990 325I
    And its leaking coolant, I cannot find where it is leaking from, where are some of the main places to check on theses cars?
    Thanks in advance for the help
  • HardTech
    • 174
    coolant hose clamps
    radiator
    water pump
    • Liam
      • 753
      Originally posted by HardTech
      coolant hose clamps
      radiator
      water pump
      Heater core
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
      • ethree
        • Aug 2007
        • 1216
        Headgasket
        • twright
          • 707
          Drive the car until it is completely warmed up. Shut off the engine with the hood closed. Leave it sit for 5 minutes. Open up the hood and start looking for wet traces.
          This is the best time to look for leaks. The engine temps are highest after shutdown and will be more likely to leak. If you wait any longer, the leak traces start to evaporate and you can't see them anymore.
          • SpecM
            • Oct 2005
            • 4531
            the cooling system?
            1989 cirrisblau-metallic 325i
