Add power steering
  • Jhinds7253
    • Jan 2023
    • 6
    Add power steering
    I have a 83 320 imported from Germany. It has a m20 engine. There is no power steering and I am putting in a z3 rack. Problem is I can not find any brackets the match what I have. Does anyone know what fits on this or a parts list for brackets and pump? I’m just going to get the chase bays kit for the lines and reservoir.
  • harrycarry250
    • Jan 2023
    • 8
    Should be pretty straightforward... You need an intermediate bracket between that mount and the actual pump, look on eBay.
    pump, bracket, reservoir, lines, fluid
    Throw in a powered rack and hook up the lines, bobs your uncle
    https://www.ebay.com/itm/27543606548...Bk9SR7Lz_f29YQ
    • Jhinds7253
      • Jan 2023
      • 6
      That’s what I figured, I was just having an issue finding anything related to this exact mount. I jus bought a pump with brackets and everything off of eBay. Going to try it out and modify as needed.
      • harrycarry250
        • Jan 2023
        • 8
        It should all fit just fine, according to the pics you posted it looks like a garden variety m20.
        Probably having a hard time finding information since it's a somewhat obscure ask.
        You will have to adapt the lines to the Z3 rack, the m20 lines will not naturally line up but you can bend them into the right location. Just be careful not to kink them. Good luck
        • TobyB
          • 5280
          www.realoem.com will give you diagrams and part numbers. The prices aren't real, though. Google will soon prove that.
          t
