Alternator Not Charging
  • hp13
    • Sep 2021
    • 39
    It is not getting charged at all with the car idling or if the RPMs are higher. The battery light stays on even with the car running. I redid all my grounds and the cables going to the starter and from the starter to the battery. I also installed a new voltage regulator and cleaned the alternator and mounting bracket. I found that the exciter wire (the smaller blue D+ wire) is only getting 2.2V and if I supply the exciter with 12V the battery starts charging. Given that the battery light comes on can I assume that the blue wires wiring is good? And if not where can I trace this wire back to find possible faults? Thanks!
  • reelizmpro
    • 9558
    If the battery light turns on with the key ON then the connection is good and it should charge the battery. Which model E30 do you have?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • hp13
      • Sep 2021
      • 39
      I've an M30B35 in there
      • reelizmpro
        • 9558
        I would look at the ETM for your particular car and compare it to the swap harness. Was it always like this since the swap? or did it occur all of a sudden one day?
        88 M3 - LACHSSILBER
