Burning smell from rear drivers wheel/tire
  • calypso rot
    • Oct 2020
    • 45
    Got done driving to bowling alley last night and was greeted with an awful hair burning like smell. Kind of like clutch definitely not coolant or oil burring. Most acute in the rear drivers wheel, seemed like it was throwing off heat. Seems to me i'm dealing with an E brake stuck on or a stuck caliper? maybe just severely worn pads, although they didn't squeak. I'm gonna check her out tomorrow (Weds) seeing if you think I'm on the right track.
  • 82eye
    • Jan 2009
    • 2108
    what's the car ?
    check your e-brake.
    • calypso rot
      • Oct 2020
      • 45
      1990 325i 2 door manual trans. Yup E brake was my first thought. I'll look into it later this week.
      • 82eye
        • Jan 2009
        • 2108
        check the cable to see if the e-brake backed off. sometimes a yank on the thing will release them. i had a stuck cable on mine. it's not always the e-brake itself, the cable sheath is able to deteriorate enough to hold the cable internally, which locks the brake.
        • calypso rot
          • Oct 2020
          • 45
          Thanks for the tip. I'm "working" from home today, I may have some time to take a look - will update with my findings.
          • calypso rot
            • Oct 2020
            • 45
            I haven’t been able to replicate symptoms. Rotors no scoring and pads are okay. Could I have had the e brake partially engaged during my trip?
            • roguetoaster
              Biggus Tippus
              • 7830
              Did you remove the rear rotor to look at the internal drum brake system and cable end?
              • 82eye
                • Jan 2009
                • 2108
                check the above post. your rear disc brakes have zero to do with the e30 parking brake.
                edit for clarity : your e30 parking brake lives inside the hat of the rotor disc. you won't see it by removing the wheels alone. it's like a mini drum brake.
