(SOLVED) Faulty Temperature gauge
  • TriStarE30
    • Aug 2023
    • 3
    I wanted to share my experience with troubleshooting the temperature gauge in my 1985 325e. I initially focused on the C101 connector and found no continuity between the engine side (female) and chassis side (male). After cleaning the contacts with Deox-IT, I inserted some scraps of copper wire into the female side to improve the connection, which finally established continuity. However, this didn't resolve the gauge issue.
    Next, I examined the motor, particularly the sensors (about 3 of them) within the thermostat housing. I realized that the gauge sensor was the one with a single blade and a brown/white wire. Contrary to online suggestions pointing to other sensors, this was the key. To confirm on your car, you can test pin 4 on the chassis side with a DVM. I also cleaned this connection, but the temperature still wasn't displaying.
    Ultimately, I took out the cluster and tested continuity between the sensor and pin 26, confirming an internal problem. When I bench tested the gauge with a 12V battery across the pins, it worked fine. I then bypassed the SI board, added an extra washer to the grounding nut, and replaced the missing grounding nut (M4x0.7).
    The combination of these actions resolved my issue. Since I couldn't find this information easily, I'm sharing my process here in hopes of helping someone else in the same situation.​
  • It's Soda Not Pop
    • Jan 2022
    • 877
    nice
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • notporgu
      • Aug 2022
      • 32
      My temp gauge is erratic, and often doesn't work at all and it's been bugging me forever. I'll try these steps and see if it helps, thanks!
