Low voltage to dme relay and coil
  • Coggat1
    • Feb 2023
    • 1
    So I have about 9.6 volts going to my coil and 9.6 going to one of the 87 pins that is red/white smaller wire. The other 87 pin gets full voltage
    I have a new CPS. New coil, I ordered a new dme relay to be safe. I’m just trying to nail down exactly what’s going on. Car started the other day for half a second and died I bridged the dme relay pins and it tried to start a bit. Now I do the same thing and it won’t try to fire over at all now.
    stomp test doesn’t work either.
    is there a search function on this site? I’d search if I knew how on here
  • TobyB
    • 5297
    the search is in the grey bar directly above your post.
    has been up for at least 10 years, miraculously. Find your
    year (or the one closest to it, but earlier) and start metering around.
    It'll take a while to get confident with the ETK, but you'll sort it.
    t
