Idle surge after catalytic converter change
  • MooN
    • Jun 2021
    • 2
    Hey all! I have an 87 325i (M20). I had it running amazing. Started up great too. Well, I couldn't pass smog so I had the catalytic converter changed. After this I am now having surges after the car is started, rough idle, bad starting. The cat swap required some changes to have it fit. Went from a 2 in 2 out, to a 1 in 2 out. The "Y" converter pipe is pre cat. Would this cause the issue? Any ideas?
    Thanks!
    1987 BMW 325ic
  • Panici
    • Dec 2009
    • 2570
    Is the O2 sensor before or after the cat?
    Did they disconnect the battery when welding up the exhaust?
    • E30Bastard
      Shimmy Shimmy Ya
      • Nov 2018
      • 245
      Did they even reinstall the O2 sensor at all haha
      "It wouldn't be there if it wasn't..." - Milton Berle
      1988 325iS - M20
