Instrument cluster light + speedo failed + weird electrical issues
  • environmentalegg
    • Mar 2024
    • 1
    Hey guys, bare with me here I just got into E30s and don't really know what I am doing.
    Recently bought a '90 325i convertible with unknown milage. Drove it back 2 hours no issues last week.
    was driving 2 days ago with my lights on when suddenly the instrument cluster lights went out as well as my speedo - everything else on the cluster works fine and the other lights in the centre work too.
    Checked fuse box - no blown fuses, smacking the dashboard will cause the speedo needle to wobble slightly (never past or close to 0, always below). I checked the ground behind the dash and all the wires seemed to be contacting
    There is a weird thing going on, whenever I turn off the headlights - stalk all the way in, the OBC digital display backlight works perfectly fine, when I pull the headlights and turn them on, the OBC backlight goes off but it still works.
    Please be patient with me and any pointers would be hugely appreciated
  • tomstin
    • Mar 2015
    • 570
    No easy answer for you. Start with the wiring diagrams for your year and model here: http://wedophones.com/Manuals/BMW/
    As old as these cars are today, wires, connectors and grounds can cause real headaches. Good luck and let us know how it goes for you.
    2004 525i Manual - 1985 325E Coupe Manual
    • mavrikno13764
      • 232
      Sounds like SI board battery issue.
      When the batteries in the Cluster start to go bad, weird stuff starts happening.
