Need additional help
  • Bourkeco
    • Jun 2024
    • 5
    I thought redoing my grounds fixed the problem I was wrong.. lol
    Hopefully someone here knows. Is there a relay that prevents the starter from cranking if it’s bad and if there is one where is it located? Everything else works fine. I can start the car with a remote starter off of the starter solenoid, but once it’s warm, it won’t crank 83 323 euro
  • TobyB
    • 5280
    has wiring diagrams.
    BMW starters can have the solenoids fail in such a way that they bind when hot- the test is to pour a gallon
    of water on the starter, and if that fixes it, replace the starter (or just the solenoid, if that's how you roll)
    t
