Temp sensor only moves slightly and never shows warm - m44 swap
  • 318istourer
    • Jan 2025
    • 16
    My e30 has had a m44 swap and the previous owner said he couldn't get the temp gauge to work properly, that its incompatible with the e30, is there anyway that I can get the temp gauge to show the car is warm, rather than just having to guess by leaving the car running for a while?
  • tomstin
    • Mar 2015
    • 569
    Here is an idea.
    ​​​​​​https://www.ecstuning.com/b-race-ger...lash-8npt~rgm/
    2004 525i Manual - 1985 325E Coupe Manual
    • 318istourer
      • Jan 2025
      • 16
      Well, for now I guess I could put a temp gauge on the trim under the steering wheel since it’s already cracked. That’s a good idea, thanks
      • 318istourer
        • Jan 2025
        • 16
        Actually, I just had a look at my engine and it’s already got that type of sensor to the coolant line, was a bit confused at first, but as mine has a electric fan it has an electric fan and the wiring looks the same to the fan from the sensor, anyway, the sensor on this engine is a 4pin as I can see 4 wires to it, but the e30 is 2, confused up to here, should I give a go replacing the sensor or leave it as I’m not wanting to open the dash cluster.
        • e30davie
          • Apr 2016
          • 1788
          I've never had much luck with the temp gauge in my e30, standard everything. seems to have a mind of its own. Sometimes it shows what seems to be correct in the middle, but most of the time it hangs around 20% of the gauge. I suspect its in the cluster itself. I ended up putting a VDO temp guage hanging below the stereo with its own separate sender. it looks alright all things considered and its never given any problems.
          • 318istourer
            • Jan 2025
            • 16
            I suspect that the engine is warm when the electric fans kick in, takes some time but I will get my mechanic to help me wire one up because then I can get an accurate temp, seems a safe bet
