electrical issues again
  • grumpygit
    • Nov 2024
    • 25
    can anyone advise the colour of the wires in the drivers door pillar for the electric windows and electric mirrors, the plastic casing that joins the door wires to the loom behind the speaker has broken, unless I get the connectors in exactly the right position will the electric parts in the door will work, so annoying, I'm thinking of joining the wires in a different way. can anyone please advise
  • 82eye
    • Jan 2009
    • 2108
    you can look them up in the etm. http://wedophones.com/Manuals/BMW/
    down load and save a copy.
    • grumpygit
      • Nov 2024
      • 25
      thank you
      • grumpygit
        • Nov 2024
        • 25
        Is there a way around the fact that the 2 connector blocks are broken, the one in the door pillar. the tabs that hold it in place are broken and the one from the door itself the clips are broken off that hold it to the one in the pillar
        • grumpygit
          • Nov 2024
          • 25
          sorted it, cut the 2 connectors off and crimped the wires together, everything works perfectly, temporary solution till I can get new blocks, if ever
          • grumpygit
            • Nov 2024
            • 25
            if anyone needs the harness pillar connectors I've re
            moved, I've managed to order the set from synergy stevenage, see pic, does anyone know what size superseal pin connectors are needed??
            cheers
