Fuel Leak Near Tank
  • Stryker
    • Jul 2006
    • 2
    Fuel Leak Near Tank
    Hi,
    I have a fuel leak from the rear of the car. It started after engine start and when I looked under the car it seemed to be dripping from the bottom of the tank and the rear sub frame behind the tank. The tank was almost empty anyway but by the time I drove it back inside the garage and put it on chassis stands it had stopped. Before it got dark I drained the tank (8 litres left) and will have a look at it when I get time.
    Does anyone have any ideas on where to start or known issues? I have replaced all fuel lines forward of the fuel filter but I don’t think I did any on top of of the tank.
    1988 325is
  • tomstin
    • Mar 2015
    • 570
    Check the overflow tank and related hoses above the right rear tire. Remove the tire, remove the plastic shield and there is the overflow tank and hoses related to the evaporator system. Take a look at REALOEM in the fuel supply system for more detail.
    2004 525i Manual - 1985 325E Coupe Manual
    • reelizmpro
      • 9558
      Look under the car and see if the filler hose is wet near the tank inlet. I've had this happen on two cars recently. Both times it was just the tapered filler hose. Both were original 35-40 year old hoses. They developed cracks near the tank inlet. I used OE BMW hose but there is also aftermarket hose available.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Stryker
        • Jul 2006
        • 2
        I’ve checked the filler hose and it’s ok but will change it anyway as it’s old. Will check the overflow tank and hoses soon.
        Thanks
        • reelizmpro
          • 9558
          If you smell fuel inside the car, pull the rear seat and check the hose connections at the pump carrier as well.
          88 M3 - LACHSSILBER
