Need advice on replacing cylinder intake manifold gaskets
  • Rosica
    • Jan 2004
    • 240
    I tried to find a vacume leak that has been haunting me. I heard a leak, I found the #6 cylinder intake manifold nut so lose, it was about to fall off. It looks like the intake gasket on #6 has deteriorated and moved a little. Next weekend I will pull the manifold and replace all the gaskets. Are there any other parts I need or should replace when doing this?
    07 335xi Sport
    00 S2k
    01 A4 1.8t-Sold
    88 M3-Sold
    91 325iC-Totaled
    89 325iS - Sold
    87 325-Totaled
  • Jordan
    • 12916
    replace the orings on the "spring loaded tube of death"
    also replace the tstat housing gasket
    https://mtechniqueabs.com/
    • Rosica
      • Jan 2004
      • 240
      I didnt really look to see what work was involved. Do I need to remove the tstat housing, it looked like a separate part? Do I need to drain the coolant? If I do, then I am doing the t-belt and water pump a the same time.
      07 335xi Sport
      00 S2k
      01 A4 1.8t-Sold
      88 M3-Sold
      91 325iC-Totaled
      89 325iS - Sold
      87 325-Totaled
      • Jordan
        • 12916
        Many many "while you are there" items. The tstat housing kinda gets in the way, IMO remove it.
        • Rosica
          • Jan 2004
          • 240
          Alright, alright.
          What is the "spring loaded tube of death", so I know what O-rings to buy.
          07 335xi Sport
          00 S2k
          01 A4 1.8t-Sold
          88 M3-Sold
          91 325iC-Totaled
          89 325iS - Sold
          87 325-Totaled
          • LowR3V'in
            • 4209
            • chrisd
              • 288
              I can't find that in the Bentley index :( wtf is it? what does it do?
              • James Crivellone
                Head Janitor
                • 6305
                Oil return line from the intake manifold's center port to the crankcase IIRC
                • chrisd
                  • 288
                  thank you. I'll remember that if I ever rip the thing apart...
                  • Axxe
                    • Aug 2004
                    • 3355
                    That tube sucks. Was a PITA to get it to line up right.
                    Keep it slideways!!
                    • Rosica
                      • Jan 2004
                      • 240
                      I am only pulling the intake far enough back to replace the gaskets.
                      Do I need to disconnect any fuel lines?
                      Do I still need to mess with the spring loaded tube of death?
                      07 335xi Sport
                      00 S2k
                      01 A4 1.8t-Sold
                      88 M3-Sold
                      91 325iC-Totaled
                      89 325iS - Sold
                      87 325-Totaled
                      • James Crivellone
                        Head Janitor
                        • 6305
                        Yes, because on the center of the head the stud is longer then the rest, so you will have to basically remove the intake manifold from the head. You can let it dangle there I guess if you wanted though..
                        • Rosica
                          • Jan 2004
                          • 240
                          Is the yes on both? What is involved in disconnecting the fuel?
                          07 335xi Sport
                          00 S2k
                          01 A4 1.8t-Sold
                          88 M3-Sold
                          91 325iC-Totaled
                          89 325iS - Sold
                          87 325-Totaled
                          • James Crivellone
                            Head Janitor
                            • 6305
                            You don't have to disconnect fuel, although if you have old and worn out lines, they may crack when you flex them moving the intake manifold
                            • Rosica
                              • Jan 2004
                              • 240
                              My car is a 92 with 106k, so they are prob ok, but I will take a look at them. Are they e30/BMW specific, or can I get them at the local parts store?
                              07 335xi Sport
                              00 S2k
                              01 A4 1.8t-Sold
                              88 M3-Sold
                              91 325iC-Totaled
                              89 325iS - Sold
                              87 325-Totaled
