Steering u joint replacement
  • dice2012
    • Mar 2021
    • 86
    Pulled off the steering linkage (airbag Car) to replace the guibo and do a steering rack upgrade. I noticed that some of the rubber on the U joint disintegrated and I’m wondering if I can use this joint or if I’ll need to get a new steering linkage. Any thoughts?
    the big D
  • Vincenze
    • Apr 2019
    • 1038
    The rubber joint is available new 32311153993.
    • dice2012
      • Mar 2021
      • 86
      I mean the actual cv/u joint inside the steering knuckle. There seems to be some rubber that has degraded in it that might hold in grease? It’s super rusty so wondering if I can just clean it up and throw lithium grease on it.
      the big D
