Electric Fan Problem
  • srider
    • May 2026
    • 9
    Hello, I had an odd problem with the electric radiator fan on my E30 this weekend.
    * Drove it about an hour, it was raining, upon arrival at the destination the electric fan turned off when the engine was shut off.
    * During the night, no key in the ignition, hadn't been started for hours, the fan came on and wouldn't shut off on it's own. Started the car, let it idle a minute or two, shut engine off and fan went off again.
    * Several hours later (middle of the night), fan comes back on. I disconnected the battery in order to get it to stop.
    Today, reconnected the battery and the fan immediately comes on, even before the engine has started and without the key in ignition. Drove the hour back home, garaged it. Fan has not come on. Everything seems normal.
    All the connections appear to be solid. It also has a brand new radiator, temp sensor and wiring.
    Any helpful thoughts or experience with my ghost fan problem?
    Thanks
  • digger
    • Nov 2005
    • 6219
    didnt f up the wiring to the switch?
    my suspicion would be one of the relays and depending the speed (normal/low speed K1 or high speed K6) it came on at would govern. The relays are hot at all times so could stick or if wiring to switch was done incorrect the control side of relay could activate or something of this nature
