whenever im taking turns and im at low rpms, i hear some type of rattle coming from the back end..i dont really know if it happens under throttle or not but it sounds loud and it dont know if it might be a driveline related issue or suspension related issue..any suggestions?
weird rattle from rear end
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
Originally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - ToyTags: None
So it's only when taking corners? both ways or only left or right? how about going over bumps? worn subframe bushings usually are more noticeable going over bumps but are a possibility, as is a bad cv joint, jack the car up and have a look at all the rubber bushings, if they look cracked and old it is highly likely they are the problem also check if the cv boots are cracked at all, a cracked boot causes rapid failure of the cv joint as dirt and water contaminate the grease.
Also be more specific than "weird rattle" if you can.
'89 Alpine S52 with goodies
my 6'ers rear calipers rattle, when I hit bumps while on the brakes even lightly no rattles, incessantly rattles over surface imperfections when not on brakes though. Weirded me out when everything was perfectly tight and it still rattled. I think the brakes are just too worn, gonna replace pads and throw some other anti rattle clips on and see if it goes away
lol i dont really know how to be more specific but here is my go, at first i thought it was something like rolling around in my trunk but i ruled that out after cleaning it up. it really happens when im in a higher gear doing low rpms around corners both ways or slight turns..but sometimes when i hit bumps it may also do it too. but it seriously sounds like something is rolling around in my trunk like a rock or something haha weird
2002 325i - DD
yes more like a fast thump, i guess ill go and get some diff fluids and see if it goes away..oh yeah and no lsd
2002 325i - DD
rsms are good i need to check my cv joints, but i changed fluid and still no luck. the noise has been getting worse with odd symptoms..the thumping/knocking noise usually happens around 2k rpms, and sometimes (and i dont know how this makes sense) when it rains it gets worse and say if im downshifting and i blip the throttle it thumps as if it has to do with raising the engine speed. this problem is really bugging me now and i dont know where i should start! i appreciate the help from you guys!
Forgot to mention, there were metallic deposits in my old diff fluid..Last edited by gtdragon980; 06-17-2009, 10:11 AM.
2002 325i - DD
