2nd gear notchification
  • cahomey
    • Mar 2004
    • 1201
    Simple question. Why is 2nd gear the notchiest out of all 5?
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
  • kencopperwheat
    King of Kegstands
    • 14396
    Re: 2nd gear notchification
    Worn synchros.
    Originally posted by Gruelius
    • cahomey
      • Mar 2004
      • 1201
      Care to elaborate? I realize its worn synchros but what creates the "notchy" feel?
      • BMW BMXER
        • 2325
        Worn synchros.
        Why is 2nd worn the most?
        Sold it.
        • cahomey
          • Mar 2004
          • 1201
          Because it it the most used
          • Rob
            • 8166
            and most abused.
            worn synchros=less 'smoothing' effect on gear changes, hence, notchier shifter
            BEERTECH
            • Kruzen
              • Mar 2004
              • 5603
              what makes it near-impossible to shift into second somtimes @ high rpm load?
              as in WOT in first, 6500RPM's, shift to second and it feels like its a wall you're trying to shift into..
              it happens every now and then.
              Who doesn't love a little BBQ?
              Griot's Garage at a Deep Discount
              • Digitalwave
                is a poseur
                • 6299
                Probably worn and/or broken tranny or motor mounts. When at high RPM's and WOT, this gives the tranny or motor a lot of chance to flex and move around, making it very hard to find the shift gates.
                RISING EDGE
                • Kruzen
                  • Mar 2004
                  • 5603
                  whats involved in fixing these?
                  • e30evolution
                    West Werks
                    • 1888
                    replacing the mount and rebuilding your shift linkage.
                    http://www.westwerksauto.com
                    • Kruzen
                      • Mar 2004
                      • 5603
                      parts/time estimate? and how crucial is this, what will happen if it goes unfixed.
                      • James Crivellone
                        Head Janitor
                        • 6305
                        2nd gear stays notchy,
                        you could also do a fluid change, toss some Redline in there, that should make it shift a tad easier.
                        Parts are around 200 bucks, if you do a short shifter when you rebuild the linkage, although seeing as you don't dig notchyness, then you may want to keep the stock throw.
                        I LOVE my notchy shifter
                        • Kruzen
                          • Mar 2004
                          • 5603
                          i don't mind the notchyness, i mind not being able to put it in second when i'm accelerating hard from stop.
                          • Digitalwave
                            is a poseur
                            • 6299
                            The tranny mounts are easier and I paid $8 x2 for them. All you have to do is put a jack under the tranny to support it and lower the tranny brace. That could all be done in 30 minutes I'd say. For the motor mounts, you have to loosen them and then jack the motor up a bit from the oil pan to get the mounts out. They are about $15 a piece I'd guess. That took me about an hour to do the first time I did it.
                            RISING EDGE
                            • brodee
                              • Jan 2004
                              • 2914
                              TJ has it right. I'd like to add that if your mounts are bad or you even think they are then replace them. They can cause a lot of other problems if you don't.
                              "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                              1988 M3 - Track Rat
                              1989 325iC M50 Vert
                              1989 325i Coupe
                              1991 318is
                              1995 318ti Club Sport
                              2006 330i e90
                              2008 Tundra Crewmax
