My compressor is not getting power. I have by-passed the pressure switch. I have tested the a/c switch and it is not working properly. If I hold it in there is continuity where there should be, but if I just push it in, there is continuity and then there is none. I have to physically hold it in place to keep continuity. The area of the switch that is giving trouble, goes to the evaporator temp switch. Where is that?
Where is the evaporator switch, trying to diagnose a/c
///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
Thanks. My compressor is not turning on. It will turn on if I jump the 12v directly to it. But when I hit the switch in the car, there is not 12v at the compressor. I have bypassed the high low switch and that did not do it either. Any idea how to check this switch or bypass it? I just want to make sure that the evaporator temp switch is not the problem. Thanks
It's in the ac/heater box, IIRC on the drivers side.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
