Engine Reving while in neutral without foot on gas??
    So I went to get in my car today and when I turned it on, it immediately started to rev. It was the weirdest thing. The car was in neutral, and I didn't have my foot on the gas. I tried turning the car on and off multiple times but to no avail. The engine will start to slowly rev up to around 4000-5000 rpms. What could my problem possibly be?
    '91 Brilliantrot 318iS - Sold
    '95 e34 s50 Touring - P/O
    '87 Alpine White 325iS - Current
    check yo ICV
    and fo vacuum leeks
    -Andy
      Perhaps a vacuum leak or a cracked intake boot/hose thing. Maybe even a stuck throttle cable?
        floor mat pushing on gas pedal. happens in my e28 alot.
        Originally posted by BillBrasky
        That's like Vlad challenging Chip Foose to a car painting contest.
        Originally posted by acolella76
        i'm pretty sure 'Phillis' is short for syphilis
        2007 CVPI, stock and slow
        1994 tercel, 5efhe swap, i/h/e
        1984 t-type, 5.3/th350 swap in progress
        My newest addition:
        Rebecca Arlene, born 4/19/2013
          I'll check those out. Thanks.
            Also check the throttle cable at the throttle body.
            I've had the plastic clip come out before and cause that very same problem.
            | Jimmy | 1999 M3 | 1986 325 ES |
              well you're checking cables check to see that your cruise control servo cable isn't binding
              '89 Alpine S52 with goodies
                I found the problem. It's solved.
                  well don't leave everybody hangin what was it?
                    I had cleaned my engine bay the previous day and adjusted one of the relay wires so it was out of position (on accident). Simple fix.
