M42 missing second throttle body plate?
  • spud814
    • 287
    Hey guys,
    I just notice that my M42 is missing the second throttle body plate. What does this affect? Will this effect how my engine runs, and what is the second throttle body plate for?
    -gil
  • E30godz
    • 1524
    uhh yes it will effect it, it would be like having a huge vacuum leak i would assume....the small plate is for part throttle driveability
    • spud814
      • 287
      Anyone else with some insight?
      • fabianyee
        • 195
        can the engine actually idle without the 2nd butterfly???
        BMWClub Malaysia
        www.bmwclubmalaysia.com
        • spud814
          • 287
          LOL it's been running fine for the last year no problem. Idles just like my 325i.
          • PanamaE30
            • Oct 2004
            • 768
            I worry for your 325i..
            LOL j/k.. that's kinda odd. maybe you have a vacuum leak elsewhere nullifying it?
            1988 325iC - "Betty" - Daily Driver/Project Car.
            1993 318i - "The Golden Dream" - Dad's Car.
            1995 318ti - "Hellrot" - R.I.P.
            • Rob
              • 8166
              or maybe the m42's TB has a different design?
              BEERTECH
              • PanamaE30
                • Oct 2004
                • 768
                The throttle body on my 318i's M42 and my dead 318ti's M42 look pretty much the same in design to my 325ic's M20...
                obviously they're not the same, but fundamentally the same.
                • spud814
                  • 287
                  i clearly dont have a idling problem at all, but what is is the purpose of this second plate then?
                  • Stu Mc
                    • 4083
                    The primary plate is the small (roughly 30mm) one, and the secondary is the larger, 54mm one--because the primary opens first when you step on the gas. The smaller one is used only for part-throttle, after more than about 1/8 throttle the secondary plate opens up.
                    Which plate are you missing, large or small?
                    Panama, all throttle bodies are fundamentally the same. Your 325i uses a ~60mm single plate that opens any time you hit the gas. The M42 uses two plates, as mentioned above. Not really a similar design to your M20 t-body.
                    • spud814
                      • 287
                      OK guys, everyone has got it wrong, i have both butterfly plates. What i'm missing is the metal plate that is sandwich between the throttle body and the intake manifold. Sorry guys for the poor description and bad vocabulary.
                      • Rob
                        • 8166
                        that would be a gasket
                        BEERTECH
                        • spud814
                          • 287
                          LOL, nope, not a gasket, i know what a gasket is. This piece is a metal piece about 1/4-1/2 inch thick.
                          • Rob
                            • 8166
                            oh oh! I know. Does it have lines running to it? if so, its the heater plate, whatever its called. helps keep the throttle from sticking in cold weather
                            BEERTECH
                            • spud814
                              • 287
                              YES!!! From what i remember on my GFs 318is i think it does have lines running to it. So thats what that thing is, hmmmmm, interesting, i wonder how it effects my car since i don't have one.
                              Thanks alot ROB and everyone else that helped me out on figuring out what the hell that stupid plate is, thanks.
