M42 missing second throttle body plate?
  • demlotcrew
    • May 2004
    • 297
    You dont need it unless you live in a really cold inviroment, BMW put these on to stop the throttle body from freezing up. Ive taken mines off not much point to it when you live in the UK.
    Andrew
    Andrew AT E30zone.co.uk | H23-is | S14
    • Rob
      • 8166
      you actually removed it? or did you just plug the coolant lines
      BEERTECH
      • demlotcrew
        • May 2004
        • 297
        I removed it and by passed it under the Inlet manifold.
        There are to plates one right inbetween the throttle body and inlet and one right under the throttle body i removed them both.
        Its dead easy to do.
        • Rob
          • 8166
          cool deal, i'll probably do that this spring. overall our winters are mild, but we do get some cold days (20-30s F), so i'm leary of nixing it now.
          BEERTECH
          • demlotcrew
            • May 2004
            • 297
            When you take it apart you will see what im talking about, you can even use on of the old Rubber pipes from the sandwich heater to by pass it straight into the Head.
            Andrew
            • JHZR2
              • Oct 2004
              • 28
              it serves as a throttle body spacer. Very common aftermarket addition on GM vortec engines, and OE on your BMW engine. Apparently it helps to smooth the airflow and the slight increase in volume also aids in drivability slightly during transient operations.
              It also gets warm to keep the throttle from sticking. However, the throttle bodi itself also has a heater connection.
              JMH
              • demlotcrew
                • May 2004
                • 297
                on the M20/M40 yes but on the M42 the throttle body has no built in heater. I have not noticed any reduction in performance by the removal of this Spacer.
