ECU #153 to #173
  • eric1855
    • Sep 2004
    • 69
    ECU #153 to #173
    If my car came with the #153 ECU (1987 325is) can I replace it with the later model #173 ECU and it work?
    Just wondering.
    Thanks
    Eric
  • M-technik-3
    • 18946
    plug and play..
    • eric1855
      • Sep 2004
      • 69
      Snug.
      Thanks.
      • hella 325
        • Sep 2004
        • 380
        whats the difference?
        Russell
        1987 325is
        1992 240sx coupe
        1994 525i
        • MarkD
          • Sep 2004
          • 488
          A few things:
          - a totally new generation of hardware in the 173, which is on one board instead of two, and more reloable
          - much better software. The maps are also bigger, and much easier to modify for performance.
          MarkD
          URL: www.dsylva-tech.ca
          • hella 325
            • Sep 2004
            • 380
            oh, and i should be able to hook up a new ecu in my 87 and it will do ok even if i have teh motronic 1.0 fule system and wiring harness?
            Russell
            1987 325is
            1992 240sx coupe
            1994 525i
            • Digitalwave
              is a poseur
              • 6299
              No, you need to have Motronic 1.1 to go to the 173 box which is 1.3.
              RISING EDGE
              • hella 325
                • Sep 2004
                • 380
                did 1.1 have 2 fule pumps (b/c) i do? or was that 1.0? cuz i have a engine from a 90 (thats 1.1 right)? but the car is from 12/86 which is 1.0? and i have a 153 ecu
                PS sorry if im jackin ur thread, just tell me to stop and i will
                Russell
                1987 325is
                1992 240sx coupe
                1994 525i
                • M-technik-3
                  • 18946
                  Guys, I had a 173 box in my 87 325iS that had a 153 box. It worked just fine. It had a TMS chip and there was a noticeable differance.
                  • coupeowner
                    • Oct 2004
                    • 50
                    You can also do the stomp test w/ the 173 ECU, not the 153.
                    • hella 325
                      • Sep 2004
                      • 380
                      stomp test?
                      Russell
                      1987 325is
                      1992 240sx coupe
                      1994 525i
                      • coupeowner
                        • Oct 2004
                        • 50
                        Do a search on how to do a stomp test (it's been a while - something like key "on" then three quick stomps on the gas pedal), but basically you can get the engine fault codes though the dash. It reads out in a series of light flashes (kind of Morse Code).
