Brake lining light
  • MillerTimE30
    • Mar 2004
    • 14
    Brake lining light
    I just replace my brakes and all that other good stuff and my brake lining light is on. Does an anyone kow how to reset it or turn it off?
    No really a big deal but it annoys me
  • dwforum
    • 220
    Same thing just happened to me, although the light seems to go on more when the roads are wet. Its intermittent but happens pretty often.
    • jblack
      • Aug 2004
      • 98
      For Miller - Did you replace the sensor or reuse the old one? Was the light on before you replaced the pads?
      For DW - you have an open somewhere that is getting wet..... I'd replace the front sensor, see if it fixes it, if not, then the back sensor. I'd imagine that it is one or the other. If this doesn't fix it, you'll need to trace the circut to see where it is open, but the best chance is one of the sensors, as they are the most open to the elements.
        • 34844
        if the light is always on, then the sensor is missing or broken. if it comes on sometimes, it's probably rubbing on the wheels and shorting out.
        • MillerTimE30
          • Mar 2004
          • 14
          I look at it again and the sensor looks in poor condition. I really dont want to place the brake sensor but other then that is there another way to get the light to shut off.
          • rwh11385
            lance_entities
            • 18403
            mine was on. I looked while my tires were being put on, a wire was hanging down.
            jacked up car.....hooked up that wire, light went off.
            The light means one of three things:
            1) brake pads shot
            2) brake pad sensor shot
            3) sensor disconnected
            edit: or more......but check those things
            • AdamF 88iS
              • 2051
              It could also mean a circuit board problem which is getting more and more common on these cars as they age. Try bang on the dash a little and see if that makes it flicker.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • PanamaE30
                • Oct 2004
                • 768
                Nothing like good, 'ol percussive maintenance :)
                1988 325iC - "Betty" - Daily Driver/Project Car.
                1993 318i - "The Golden Dream" - Dad's Car.
                1995 318ti - "Hellrot" - R.I.P.
                • Kruzen
                  • Mar 2004
                  • 5603
                  i replaced my brakes (rotors, pads, sensors) about 7k miles ago.. about 3k miles ago they started flickering alot, and then they just stay red all the time now.. i'm too lazy to go check it out cause ik now my brakes are fine.. but yea.
                  Who doesn't love a little BBQ?
                  Griot's Garage at a Deep Discount
                  • DanGillan
                    • Mar 2004
                    • 4061
                    pulling the cluster takes like 10 minutes max, pull it out, and remove the break lining bulb, as long as your not stupid, and keep an eye on your breaks, you dont need the idiot light, just take it out....
                    Dan
                      • 34844
                      they cost $5.. replace the damn sensor :?
