325i & 325e Clutch's
  • Luda30
    • Oct 2004
    • 57
    Is it true that the 325i clutches are different from the 325e clutches?
    If so what are the differences?
    TIA
  • Luda30
    • Oct 2004
    • 57
    I found the answer else where and for others that may not know.
    No it will not work unless your car was built in 5/86 or newer up until late 88.
    • chrisd
      • 288
      This is because the older ones have the single mass flywheel, I assume? Is there any other model that is the same as the older e?
      • Digitalwave
        is a poseur
        • 6299
        If you use the 325i flywheel and throw out bearing, you can use a 325i clutch on a 325e car.
        RISING EDGE
        • James Crivellone
          Head Janitor
          • 6305
          and good luck getting the speed reference sensors to read a flywheel with no tab ;)
          • trashcop 80s 80s
            • Jun 2004
            • 1130
            So is the clutch I am selling you going to work on your car? If not I will send your money back.
            • trashcop 80s 80s
              • Jun 2004
              • 1130
              Will a clutch kit from an 89 325i work on his 11/85 production 1986 325e? He hasn't replied and I want to hurry and ship this out.
              • James Crivellone
                Head Janitor
                • 6305
                if the pressure plate fits on the flywheel it will work, took me 2 clutches to find the one I needed.
                I am running an 89 325i clutchkti on my post 4/86 dual mass flywheel
