are they the same? i have an early 84 318 jst wondering if they have the same calipers as the 325i cause i jst picked up some frrom an 87 325i and they look the same.
318i vs 325i brakes.
Tags: None
trent
Re: 318i vs 325i brakes.
Originally posted by ZiMMieare they the same? i have an early 84 318 jst wondering if they have the same calipers as the 325i cause i jst picked up some frrom an 87 325i and they look the same.Comment
Originally posted by trentOriginally posted by ZiMMieare they the same? i have an early 84 318 jst wondering if they have the same calipers as the 325i cause i jst picked up some frrom an 87 325i and they look the same.Comment
Originally posted by Robif you're talking about later model (87+) 325i and 318i/is (90-91), yes, the front calipers are the same.Comment
^^^ is it slightly different and how can u tell the difference they look identical. :(Comment
By the part numbers, the 325e/325i uses a thicker rotor so the clearence between the pads has to be more, thus the caliper wider.
THEY ARE AN UPGRADE FOR YOUR PRE 85 318i GO AHEAD AND BOLT THEM ON.
Sorry but it's been said 2 times there different.85 325e 2.7 ITB'd stroker
^^ sorry dude jst a bit slow today.
thanx for all the info. this wiill help me alot once my m20 its ready..Comment
