Bump for related question -
Can the fuel pump itself leak? I had what appeared to be a fuel leak near pump area that usually showed up when I filled the tank. I do not have the accumulator.
This past week, I dropped the tank to check to see if there were any rust holes on the tank itself. Tank looks good on the top side - dirty, but no wetness. Some paint peeling/flaking off on the left-hand side at the seam and above (but this could just be from brake clean when I changed the filter). Large diameter rubber line looked good. Basically, no signs of leaking lines or tank. Newer fuel filter. This leaves me with just the pump itself - so do they ever leak? its still pumping fine (good PSI, not noisy).
Any other potential culprits?
