Auto vs Manual Radiator.
  • BS87
    • 1606
    Searched and could not find it. I've know there is supposedly a difference between the two for a while now,and never cared enough to look it up, but what exactly is it?
  • jblack
    • Aug 2004
    • 98
    I don't know this first hand, but got this from the mechanic that is doing my swap....I was looking through the ETK trying to be thorough on the swap - I noticed that the radiators were different too - he said that there is a radiator cooler for the automatic built into the radiator that is not used or needed on the 5 speed. He said it was only a problem if you were going the other way (5 speed to manual).
    BTW, the throttle body is different, and an exhaust hanger is different - that is it for the non obvious stuff - and none of that is of any concern to the swap....
    Hope this helps - I also hope this is not spreading incorrect info....
    • T.Dot E30
      • Mar 2004
      • 536
      I know on other cars it was bcus there was a tranny colder on it, but with the manual u didn't need it, so u'd jus drain it and leave it disconnected.
      Not sure if thats tru with ours, since the tranny cooler is seperate from the rad.
      • Matto
        • Jan 2004
        • 800
        It has hookups for the auto trans fluid cooler.
        • ///M42 sport
          • 3952
          • george graves
            • 19998
            The autos rads work on both manual and auto cars....
            I have one for sale if you need one ....
            Originally posted by Matt-B
            • Axxe
              • Aug 2004
              • 3355
              The throttle bodies are the same (at least in '87)
              Keep it slideways!!
              • jblack
                • Aug 2004
                • 98
                Not necesarily. Part number for the throttle body (actually, the correct name is Throttle Housing Assembly) for a car with a Manual is 13-54-1-716-065. With an Auto, it is either 13-54-1-716-065 or 13-54-1-716-066. The difference is "Code AL"" or "Code AN""
                Not sure about the AL or AN reference on the auto, but there is a potential difference here.
                BTW, this is directly from BMW's ETK -
                • Matto
                  • Jan 2004
                  • 800
                  It probably has somthing to do with the cable attachment for the transmition on an auto.
