Speedo WAY off!
  • sector6
    • 909
    Speedo WAY off!
    Hi guys, Hope someone might have some insight into this problem...
    My car, 89' 325is all original motor/tranny/rear end/ stock wheels and stock tire size.
    Problem: Speedo is reading 12mph faster than I am actually traveling. I calibrated it with my buddies GPS. When I'm going 50mph, the speedo reads roughly 62mph???
    This is a major kick in the dick as the cops around here are BALL BUSTERS!! If everything is original spec how can it be so far out of wack? Only a matter of time before I get popped by the PO-PO!!
    Not sure what to do on this one...
    Any ideas?
    Thanks!!
  • CarsSuck
    • Oct 2005
    • 968
    Well GPS isn't the most accurate method of checking your speedometer.
    What is your actual tire size? A lot of shops will put 195/60/14s on cars and thats incorrect. 195/65/14 is. 205/60/14 is slightly undersized, but only a little.
    --Will
      • 34839
      You said stock tire size, but early E30s actually have a smaller diameter tire. so what size are you running?
      changing the transmission and diff wouldn't make a difference either since all BMW speedos use the same toothed wheel sensor.
      • sector6
        • 909
        Thanks for the replys...
        Without running out to check, I'm pretty sure they are 195/60/14. I'll double check after I get out of work.
        Edit: would running 195/60's vs 65's really make it read that far off though?
        • CAOSyAMOR
          • Oct 2007
          • 789
          based on what you said, you should be travelling slower than the posted speed limit if referencing your speedo. U worried about getting pulled over for driving too slow?
          Evolution of My E30 M3Recent PicsSC*AR
          • sector6
            • 909
            Originally posted by CAOSyAMOR
            based on what you said, you should be travelling slower than the posted speed limit if referencing your spedo. Worried about getting pulled over for driving too slow?
            no, it's not that I'm worried about going too slow. I can't trust what speedo says. I try and do what "seems like" (say 45mph) but I just never know for sure. Just waiting for one of these dick eaters to fuck with me. :D
            EDIT: Diggin' your e30 M3, very nice looking!
              • 34839
              it's a 3.2% difference in size. Not quite the full 12% you are seeing but it's a good chunk of it.
              • sector6
                • 909
                what are the odds my wheel sensor took a shit?
                • Stevie30
                  • Apr 2007
                  • 1534
                  Try this link: http://www.r3vlimited.com/board/show...te+speedometer
                  1991 325ic and 1991 318is
                  • sector6
                    • 909
                    Originally posted by Stevie30
                    thanks! Don't know how I missed that post :oops:
                    ...this opens up a whole ton of stuff I was hoping not to have to get into!!...lol
                    I'll read through it and hopefully come up with a solution.
                    Why can't it ever be simple, haha!
                    Thanks for the reply's everyone, and for trying to help me out! 8)
                    • sector6
                      • 909
                      After reading that, I'm still at where I was. Thanks though!
                      It had more to do with the odometer than the speedo.
                      I'm just going to buy a speedometer sensor from BAV (Part # : 62 16 8 355 008 ) and start there. I don't need to get into dickin' with the cluster at this point as the speedo seems to function just fine.:D
                      I'll let ya know how it works out.
                      Thanks!
                      • BTP325ic
                        • Apr 2009
                        • 700
                        WTF who needs a speedo.
                        • sector6
                          • 909
                          The ball bags in Blue, that's who
                          I could give a shit personally.
                          • Red88
                            • Nov 2008
                            • 1161
                            Mine's 9 mph off at 30 mph. My car might only have 12,000 miles on it.
                            Have you made a purchase from www.blunttech.com recently?
                            sigpic<< wrecked
                            • mattdk318i
                              • Jun 2006
                              • 3953
                              same here, Almost all of the E30's ive owned have been at least 5mph off, And on the slow side.....The first one to be right on the money is my 332i....Simply because im using the E36 electronics
