Aux Fan - is this sufficient
  • Mohammed_A
    • 344
    Im currently running my aux fan on low speed for radiator cooling and is currently doing the job perfectly, my concern is that do these fans give trouble? should i install another fan as backup? i do alot of long distance driving and dont want to overheat....please help
  • e30 gangsta
    • 3877
    You do not have a fan clutch installed? The aux fan is used mostly for the a/c.
    • Mohammed_A
      • 344
      sorry my fault for not stating that i did the s50 swap and deleted the viscous clutch fan
      • dude8383
        • Jan 2005
        • 10387
        for me it was sufficient in the colder months however it will get hot in traffic. i bought myself one of these to help keep temps down. i haven't installed it yet but will most certainly post pics and results when i do. i hope to install it over the weekend along with my a/c!!!!
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          the aux fan works fine for me, sitting in traffic with a m42 radiator, it barely passes the 1/4 mark
          Also Mohammed, as long as you dont sit still like in traffic long distant driving isn't a problem. As long as there's airflow you'll be fine
          • Mohammed_A
            • 344
            thanks guys .... but what im actually looking at is the durability of the aux fan, sure it works perfectly for me too and also if i stand in traffic it seems to do the job.....should i install another electric fan for backup???
            • whodwho
              • Jun 2008
              • 1547
              Are you running it full time or thru the fan switch?
              I run mine with the fan switch and it rarely comes on. Some run it full time and I often wonder if that is blocking airflow when driving at speed...
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                Mohammed, I suppose you can never be too safe
                • Hallen
                  • 1008
                  As long as the wiring was good and the motor isn't getting hot when in use for a while, I wouldn't worry about it. If it dies, you can drive a good long way without it as long as you keep moving. Once you have to stop for traffic, it's going to heat up. Then you turn off the AC, turn on the heater with the fan on full bore, and you can still make it a bit further as long as it isn't boiling hot out.
                  In other words, it isn't as if you have to pull over and stop because the aux fan died. You probably wouldn't even notice it until you hit stop and go traffic.
                  I saw a lot of nice E30's in Cape Town when I was there a year ago.
                  1987 E30 325is
                  1999 E46 323i
                  RIP 1994 E32 740iL
                  oo=[][]=oo
                  • Knockenwelle
                    • Jul 2008
                    • 395
                    I dunno about the fans on our cars specifically, but most of the electric fan failures I've seen are motor bearings, which will give you plenty of warning. One in a buddy's daily has made intermittent bearing noise for months, but has still not seized up. The only time I saw a motor fry internally was because the bearings went, the fan locked up, and the oversize fuse some asshole put in the fan circuit didn't blow before the motor did. I wouldn't carry a spare...
                    Mike
                    '91 325i track car. Mostly...
                    • Mohammed_A
                      • 344
                      Im also using it through a switch......
                      • Mohammed_A
                        • 344
                        Thats good news......
                        we do have quite a bit of e30s here in SA, but nothing compared to the ones u guys have....
