Removing ignition key lock cylinder
    I currently have a key broken inside. I can turn the key to the on position and stick an allen wrench in hole to retract the retaining pin. I can't pull out the cylinder though. I've tried to pry it out with no luck. Am I going to have to just bust it or drill it out?
    I think if i remember correctly, put the ignition postion on acc and stick a thin peice of metal in that little gap (hole) around the edge of the cylinder. And as you push in that little hole, pry out the entire lock cylinder.
    i'm sure someone will chime in.
    Good luck
    Justin
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
      The lock cylinder needs to be at a specific turn before you can stick a pin or thick enough wire into a hole for it to release.
        Yeah I can stick it in no problem in the correct location, but the cylinder won't budge
          The nail that you stick in has to be pointed or else the cylinder will not release. It also has to be the perfect size/thickness too.
          The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
            omg omg omg.....the correct position is NOT the acc position. At least for me. It was about 10 degrees before it. Slid the pin in and it basically fell out. FML!!!
            hahaha wasted hours on that damn thing.
