Caliper rebuild inq???
  • el_4ever
    • 145
    Where do you locate and purchase a caliper rebuilt kit and what is the price....?
    Is there a writeup any where, Jordan?
  • Jordan
    • 12916
    If you need a writeup, you need to not do it yourself.
    Caliper rebuild kits are CHEAP, and can be had at autoparts stores and online retailers.
    https://mtechniqueabs.com/
    • el_4ever
      • 145
      it's that easy, huh...
      ....i do everything myself....if i break it, i fix it again. share your knowledge brother.
      • Beej '86 325es
        • 2639
        I got my rebuild kit from Bav. Auto. It was pretty easy, I hooked up the hole for the brake line in the caliper to the air compressor and shot out the piston. Aim it at the ground into some towels or something though, that piston could kill somebody. Then you just take off the metal ring holding the boot on and take off the boot. Clean it with some brake fluid, grease the piston with caliper grease, slide it back in and install the new rubber boot and metal ring.
        Pretty easy. Good luck!
        -Brandon
        '86 325es S50
        '12 VW GTI Autobahn DSG
        '03 540i M-Sport (sold)
        '08 Jeep SRT-8 (sold)
        For sale:
        S50 TMS chip for Schricks
        • el_4ever
          • 145
          cool man...let the knowledge flow.that's what i'm talking about.
          i guess i know what i'm doing this weekend!!!
          • arnoldgtr
            • Mar 2004
            • 153
            Instead of aiming the piston, place a wood block or old brake pad in the caliper opposite the piston before applying the compressed air. Not too much pressure....50 PSI should be plenty. Place a rag over the whole mess so you don't splatter brake fluid everywhere.
            Pull off the dust boot and carefully pry the seal out of the caliper bore.
            Clean all the crud out of the piston bore with brake cleaner and let dry. Use ONLY a plastic scraper or fingernail to clean the piston.....a scratch on the piston will destroy the seal. Remove the bleeder screw and clean the passage. Blow it out with compressed air.
            Install the new square O-ring seal in the caliper first.
            The dust boot is internal on the front calipers. Lube the piston and caliper bore with clean brake fluid and slide the new dust boot over the center of the piston. Don't put the dust boot in the piston groove yet. Slide the boot to the bottom end (flat end) of the piston and insert the boot in the groove in the caliper. Making sure the boot is in the caliper groove all the way around, insert the piston and squeeze it in about halfway. Then pull the outer part of the dust boot out to the piston groove. Now you can press the piston the rest of the way into the caliper. Take care that the boot isn't pinched by the piston. If the boot is properly installed, it will be even all the way around.
            On the rear calipers, the boot installs on the outside of the caliper. In that case, go ahead and put the boot on the piston groove before installing it. Press the piston all the way into the caliper, then stretch the boot around the lip on the caliper bore. Install the steel ring to hold the boot on the caliper.
            John
            88 ///M3 Cinnabar
            84 318i Black
            • arnoldgtr
              • Mar 2004
              • 153
              And another thing....buy one front kit and two rear kits. For some reason, the front kits are for two wheels and the rears are for one wheel.
              John
              88 ///M3 Cinnabar
              84 318i Black
              • Digitalwave
                is a poseur
                • 6299
                True story.
                RISING EDGE
                • Charlie
                  kid tested, administrator approved
                  • 6686
                  Verified x2, I think it's a girling "parts bin" issue. I believe some older jags use the same piston setup, but for a dual piston caliper.
                  -Charlie
                  Swing wild, brake later, don't apologize.
                  '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                  FYYFF
                  • el_4ever
                    • 145
                    COOL...appreciate all responces
                    • Beej '86 325es
                      • 2639
                      Heh heh. I tried a block of wood first, but the piston broke the wood in half and somehow the piston was became jammed in the caliper. We then maxed out the compressor and it still wouldn't come out. Ended up using a vise to jam it back in, then hooking up the compressor again. :)
                      -Brandon
                      '86 325es S50
                      For sale:
