Hey guys,
I'm stumped and need some help please. I have an 89 325i. I purchased the car this way but whenever the car sits overnight, or after driving, 15 - 20 minutes, I run into a long/hard start issue.
Basically when the engine is cold, I'll have to crank the ignition for a good 5 - sometimes maybe 15 seconds before it fires up. When the engine is still warm, it fires up no problem. I've checked the following so far:
1. Fuel pressure. It's fine. I even replaced the FPR with a spare one known to be working and in addition, installed a fuel check valve at the fuel pump.
2. Air. There are no vacuum leaks. (Not that I can find anyway but visually looking at the intake boot (AFM-throttle body) there are no signs of cracking.)
3. Spark - I've only so far checked my cap, rotor, spark plugs, ignition timing, and spark plug wires. I have yet to check the coil (not sure how to.)
4. Unrelated but battery is charging properly at 14v and sitting at 12v when the car isn't running.
Any leads? Remember - the car fires up okay when the engine is still warm.
Thanks!
Thanks!
