Hello All ! Need some help with 85 318i
  • 85-318i
    • Nov 2004
    • 5
    The car starts and runs good until you hit the gas and the RPM's go past 3500
    Then it just quits?????
    If you feather the gas pedel it will run BUT very sick!
    HELP!
    :shock:
  • kencopperwheat
    King of Kegstands
    • 14396
    How long has it been since you've replaced:
    -Distributer Cap
    -Rotor
    -Ignition Wires
    -Spark Plugs
    Originally posted by Gruelius
    • grlaneriejr
      • 321
      Do what Ken said. Also, look at fuel filter.
      How does it drive?
      • Easily Distracted
        • Sep 2004
        • 214
        If those don't work, there's a good chance its the Air Flow Meter. The board that the arm sweeps across as the flap opens wears out after a while. Mine had a definite stumble around that RPM until I got a remanufactured one.
        Also chek the vacuum advance. I'd do that first since it doesn't cost anything to check.
        • 85-318i
          • Nov 2004
          • 5
          Its good to know all the things that make em fall!
          So thanks
          It was the fuel pressure reg.
          Cheers
          • euromotorwerks
            • Nov 2004
            • 18
            I second that... I think the afm is suspect..
            • Nick325is
              • 1409
              -Distributer Cap
              -Rotor
              -Ignition Wires
              -Spark Plugs
              Learned your lesson after the distributer cap indicent
              I did the same thing with mine. I went to replace my cap and rotor last summer and both were about destroyed. Replacing them made a world of difference.
              Nick
