In my 1990 325i check panel coolant light is always on. I have proper coolent level and sensor seems intact... any advice on how to fix it??? Thanks
check panel coolant light on...
"i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulleTags: None -
Agreed, they all fail over time. I believe it's just a magnetic ring around the foam float that acts as a switch, and it deteriorates easily. Get a new one, it's really hit and miss with used sensors, even if they were good when removed.
You can put a jumper wire between the two wires that go to the sensor to test the rest of the circuit. The light should go off with the wires connected.Comment
