Reverse Lights Out
  • kencopperwheat
    King of Kegstands
    • 14396
    Reverse Lights Out
    My reverse lights finally stopped working completely the other day. For a while they'd come on about every other time I put the car into reverse, but now I get nothing. What are the first things I should check out? And yes, the bulbs are fine.
    Originally posted by Gruelius
  • hamann318is
    • 3382
    What type of trans fluid do you use?
    I've read that using syth in the trans can gunk up the switch in the trans, preventing it from working.
    The BMW 318 is back. With a vengeance.
    • kencopperwheat
      King of Kegstands
      • 14396
      Redline MTL
      - I posted something about it messing up the switch a while back
      • LikeCDoos
        • Jan 2004
        • 2522
        mine went out about a year ago...i just wired up a switch. I turn them on if i need them...if not i don't worry about it.
        • mikeedler
          • 6707
          please, that is the most half assed thing i have heard in a long time. I t
          is so easy to replace the switch on the side of the trans. About a 5 min. job.
          just replace the part, its a 10-15 year old switch, its gonna go bad sometime.
          • ///M Powered
            • Jan 2004
            • 1109
            Mine didn't work either, taking off the shift boot revealed a cut wire so :?
            • dwforum
              • 220
              I had the same problem. Thought it was the switch, but it ended up being a split in the wire under the shift boot.
              • kencopperwheat
                King of Kegstands
                • 14396
                What color is the wire that was split?
                • LikeCDoos
                  • Jan 2004
                  • 2522
                  I think the reverse light wires are green and white...not 100% though
                  • ///M Powered
                    • Jan 2004
                    • 1109
                    mine is green and blue
                      • 37829
                      What are reverse lights?
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • ///M Powered
                        • Jan 2004
                        • 1109
                        The white lights on your tails.....
                        • PanamaE30
                          • Oct 2004
                          • 768
                          *idea*
                          lol.. if i had that i'd turn that crap on for every punk that tail gated..
                          that'll get their attention asap lol...
                          1988 325iC - "Betty" - Daily Driver/Project Car.
                          1993 318i - "The Golden Dream" - Dad's Car.
                          1995 318ti - "Hellrot" - R.I.P.
                            • 37829
                            I was :jk: man
                            Grover Beach, CA
                            www.BimmerHeads.com
