I have a Bentley manual, and I've found some DIY articles on this, but they are all woefully inadequate on the following topic:
How can you lower the rear window when it isn't working?!?
You see, to get the regulator (and motor) out, I will need to remove the 2 bolts that hold the regulator to the glass. To do this, the Bentley manual helpfully suggests lowering the window halfway (so do some other tech articles out there). This would be great if my window could lower itself, but it can't. I tried pulling down on the window as much as I was comfortable, and no dice. SO...
How do I get the window down to where I can get at these bolts when the window does not lower itself?
