Loud Squeal?
  • DarkWing6
    • Apr 2004
    • 7144
    Loud Squeal?
    Every once in a while when I accelerate/give it gas my car will squeal a little. I think it only does it when the car is not warm. I have only noticed it ever since the weather has gotten cold and I don't think I have heard it after I have driven it a while. What could this be? Do I just need to let my car run a little longer before I drive it?
    TIA
    Derek
  • Bill 84 318i
    • 1600
    If your belts are new, check the tension.
    If they're not, replace them.
    • euromotorwerks
      • Nov 2004
      • 18
      could be more than just a belt. The sound is most likely a belt but the alternator bushings is where I would look. Just look down from the top side of your engine and see if the alternator is straight accross from your crank pulley. I would suspect its (alternator) bowed in or bowed out this is common on our cars after we get some miles on them..
      • DarkWing6
        • Apr 2004
        • 7144
        I just replaced my alternator belt so.......I bet I should tighten it a bit.
        • bimmer8604
          • 3017
          mine does this too, except ONLY when the alternator is under heavy load, like when my lights are on. I hate driving at night now. Ill check the bushing and make sure its where its supposed to be.
          Kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
          • DSchultz325e
            • Aug 2004
            • 1158
            mine used to do it but i was too lazy to source which belt it came from due to me not having any friends. i tightened them all up and now it makes no noise.
            I retired my E30 for now...
            E46 323i
            David Schultz
