SMT5 vs SMT6
  • fabianyee
    • 195
    SMT5 vs SMT6
    can't seem to find any info on SMT5 but more on SMT6..
    Reason I asked is that I'll be getting a used unit of SMT5. so maybe some of u might know something about SMT5....
    1 question I would like to know is whether turbo application is ok with the SMT5 especailly with extra injectors...
    May upgrade to SMT 6 later but will try the SMT5 first and then replace the AFM with a MAF...
    have been planning the MAF conversion for the longest but was waiting for good deal to come along... looks like time is almost ripe...
    BMWClub Malaysia
    www.bmwclubmalaysia.com
  • Digitalwave
    is a poseur
    • 6293
    SMT-7 is coming out soon, I'd imagine the SMT-5 is way out to date. Pony up and at least get the 6 if you are going to spend all the time to do a MAF conversion.
    RISING EDGE
    • mspiegle
      • 1026
      i believe the SMT7 is already out, but the only reason to upgrade to it from the SMT6 is if theh SMT6 doesn't support your car fully. I'm sure gunni will get in here and set us straight.
      IIRC... the SMT5 should be good enough for a MAF conversion... its only missing a few features from the SMT6 that aren't needed for MAF conversion.
      Michael Spiegle
      '01 Ford Escape / Daily Driver
      '99 M3 / Track Car
      '87 325is bronzit / wtf car
      '06 Daytona Triumph 675 / Daily Rider
      • fabianyee
        • 195
        SMT7 is out but selling along side with SMT6 as SMT7 is made to cater for engines which can use the SMT6 (i think one of those engines is the rotary engines.)
        As for SMT5, unless I go the forced induction route, SMT5 is more than sufficiently...
        I call alwsy offload it if I decide to upgrade to SMT6 later..
        BMWClub Malaysia
        • schmick325
          • May 2004
          • 63
          bugger the MAF, get a MAP sensor hooked up to that SMT-6.
          Its not too hard to do.
          Signature removed by R3VLimited staff due to a violation of the signature rules
          • fabianyee
            • 195
            anyone done that before??? MAP sensor conversion?
            BMWClub Malaysia
            • mspiegle
              • 1026
              I would imagine that its a bit more tuning work than a MAF... but probably not too bad. Honestly though, if you're looking to completely eliminate intake restriction, look into an alpha/n system. You probably won't be able to notice a huge diff between the MAF and MAP...
              now, if you're going FI... MAP sensor all the way.
              Michael Spiegle
              '99 M3 / Track Car
              • Chris E30 Cab
                • 866
                Hey Fabian, check with Calvin since he's runnin the SMT5 on his stroker.
                • fabianyee
                  • 195
                  Reviving this thread of mine....
                  Anyway, I've bought an used unit of the following BOSCH MAF with 6 pins and it matched the AFM socket for the M42....
                  Anyone use this MAF before for MAF conversion.
                  The part no is :
                  0 230 213 011
                  1 730 074
                  BMWClub Malaysia
                  • mspiegle
                    • 1026
                    I haven't. Find a wiring diagram for the car and get a pinout. Chances are, theres a ground, a power, and a signal at the least.
                    Michael Spiegle
                    '99 M3 / Track Car
                    • fabianyee
                      • 195
                      There are 6 pins on this MAF....
                      And any idea where to find the diagram?
                      BMWClub Malaysia
                      • mspiegle
                        • 1026
                        goto a local auto retailer and look for a manual for that car. see if they have the pinouts you can write down on paper.
                        get a copy of mitchell
                        theres some site online that has wiring diagrams... i can't remember the URL. someone here might chime in w/ the answer.
                        Michael Spiegle
                        '99 M3 / Track Car
