I need to replace the light behind the temp adjuster dial. I have the bulb and everything, but I'm not sure how to get in there and replace it. I have the Bentley Manual and have been searching it for about 20 minutes to no avail. Can any one point me to the mystical page number or tell me how to do it? Help would be much appreciated.
Replacing Dash Lights
you have to remove the gauge cluster and then replace the bulb. there is no way to fit your hand up there or replace it other wise.
contact me if you need more information
-cam -
1. remove the radio.
2. reach down by the dial and pull out bulb there are two wires leading to it.
replace the bulb and reinstall.
-camComment
nope sorry man the only way is to get out the radio.
i hate to break it to you :(Comment
If youre as resourcefull as me youll find a way to remove the stereo. I can assure that a thin, blunt edge letter opener easily slides into the sides of a pioneer headunit. Do one at a time, tugging on the side of the stereo enough to disengage the lock and then on to the other side. It works for other brands too :)Comment
Yes I need to replace these lights too. What bulbs do I need, and is it possible to get my Clarion headunit out? I know nothing about this headunit. It takes me a minute just to figure out how to change the darn station.
Thanks.Moving sale: Everything Must Go!
FS: 2001 740iL Sport, low mileage..... SOLD
FS: 1990 Mtec II 325iS, $12,0K OVNO
FS: 2003 Honda Odyssey EX-L Navi..... SOLD
FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
Extreme 325iS (well, slowly getting there, anyway)......
Almost too many mods to list ;-)Comment
i remember a LONG while ago (like 3 years ago) this happened to me, too. I was able to shimmy my hands under the console but it was a PAIN IN THE ASS. i did not have to remove the radio and was able to do it with everything installed. you might have an easier time if you unscrew the whole console part (as per the obc backlight install) and push the console out for easier access. i just got through fixing my backlight and it seemed like all those parts were much easier to get to. I'll check on it.I retired my E30 for now...
E46 323i
David SchultzComment
Ken,
If you haven't already attempted to remove the stereo there is a much easier way to do this. I had to replace both my bubs down there. Here is what i did, it's hard to explain but i'll try my best.
-Pop the small covers next to your hazard button off and there will be 2 small screws up to the top.
-Then there are 2 more bigger screws in the very bottom above the small tray.
-After that pull the 2 knobs off and 3 slide tabs
-Then pop off the small cover over the 3 sliders, which exposes 4 more screws
-Unscrew them and the whole front part (radio obc and all) will pull right out.
-You will see the 2 small bulbs in the bottom left and top right of the unit.
Hope that makes sense good luck
-WestonComment
Sweet diagram/description. Can anyone tell me the bulbs I need before I go opening it up? Can I use wide angle LED's?
when I replaced mine, I HAD to get the bulbs from the dealership. I don't remember what the bulb size was exactly, but the local auto parts store did not carry them.Originally posted by sweetride01Sweet diagram/description. Can anyone tell me the bulbs I need before I go opening it up? Can I use wide angle LED's?
Thanks.~ Go Canucks Go! ~
