Finicky door latch? Doesn't close all the way easily
  • sonick
    • Aug 2009
    • 48
    Ok so my drivers side door is very finicky. It only closes fully and tightly when you slam it with a certain force. Too little or too hard, it'll just bounce and stay semi-latched (i.e. it won't open without pulling the handle, but at the same time it isn't closed fully).
    What is the issue here, do I have to grease up the latch?
    That can be caused by gummed up or lack of lube in the latch. You can try a bit of Lubriplate on the parts of the latch you can reach, but if that doesn't help you'll need to remove the latch from the door, clean off the old grease with solvent, and re-lubricate with Lubriplate (or similar)
    • Jean
      • 18228
      Or it(or the door) needs alingment..
