Rear bearing replacement.....use air impact?
  • Av8r
    • Dec 2006
    • 49
    I'm going to be replacing my rear wheel bearings this weekend. I have a borrowed rear bearing tool already, but I'm wondering if it is recommended to use an air impact gun for removal or installation? I figured probably not for installation, but I don't care if I tear the thing apart on removal. Just wanted to save some time if possible :)
  • transatlantic0207
    • Sep 2007
    • 1624
    ok do you have a machiner nearby....take off the whole trailing arm and have him pull the hub and press the bearing in. It'll save you TONS of time and effort!
    I tell everyone this when I see a rear wheel bearing thread! Good Luck
    (OO≡≡[][]≡≡OO) ///Motorsport
    In this world, things aren't black & white. Its Delphin!
    Parts, Buy Them--> http://picasaweb.google.com/transatl...eat=directlink
    Snowboard & video game stuff --> http://r3vlimited.com/board/showthread.php?t=148645
    Originally posted by Steve92E34
    Your car is breathing my air, and so are you.
    AND you are both still slow
    • FredK
      • 14761
      If you're using the B90, do not use an impact gun. Doing so can mar the internal splines of the hub if the tool gets misaligned and the screw threads start digging into the hub. Also, the thrust bearing is not meant to take impacts like that. Just use a ratchet--it doesn't that that much longer.
      • guibo09
        • Dec 2008
        • 834
        if you use the tool properly, ie press on the correct race for the correct step, there is no problem in using an impact. if you dont press the correct race, you can damage your bearing even with a ratchet.
        90 E30 325i
        • gtarwiz
          • Jan 2009
          • 591
          I agree with transatlantic, just take your trailing arm to a machiner or someone who can press it out and press the new one in. Way less of a headache and have it done right the first time around.
          BMWCCA # 482566
          Originally posted by nando
          also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
          Check out my Leather Shift Boots for Sale Here
          Check out my other work with my GF Here Great gifts for your Wife or GF
          • StereoInstaller1
            GAS
            • 22679
            Sir Tools says to NOT use air tools on anything they make.
            John Sir seems like he knew his shit, I would do as he says.
            Closing SOON!
            Thanks for 10 years of fun!
            • tinkerputzer
              • Jun 2008
              • 508
              Taking the trailing arm off is silly and a complete waste of time. Not to mention you'll have to pay to get the press work done. If you borrowed the proper wheel bearing tool, that will work just fine. Just take care not to damage the threads or splines on the axle stub. I recommend lightly chasing the splines with a file prior to installation. I wouldn't use an impact wrench for anything on this job either.
              • transatlantic0207
                • Sep 2007
                • 1624
                its silly if someone has no access to the the press. Hence the reason I asked 'do you have...' its inexpensive and easy with less grunt work. What's silly is people not using the pullers correctly and destroying the hub and the new bearing. Even without the puller I've seen people bang on the hub and/or bolt on rotors reverse and bang that way and reverting to flintstones carwork.....if you don't know what you're doing I recommend doing my way and paying no more than than a dub to have it done properly. yabba dabba doo!
                *edit air tools are bad idea, and if you do it anyway it's a bad habit to get into!
