Failed Smog
  • antc08
    • Aug 2009
    • 19
    Failed Smog
    Hey Guys,
    Posted on the other forum and though I'd post here also.
    I passed everything except the NO (PPM) at 15mph, measured number was 1018 and max is 815. I didn't really get to warm up the car before getting the test done. Do you think I should do some spirited driving and retry? Any suggestions is much appreciated.
    Thanks in advance!
    '14 S4
    '04 M3
    '79 911SC
  • Conki
    • 1254
    Run 91 octane, that should do the trick. Also warm it up of course.
    My number was 1880 on the first try, there was no way around it, I had to replace the cat. You should be able to eliminate the difference however.
    1992 BMW 525iT Calypso
    2011 Jeep Wrangler
    • antc08
      • Aug 2009
      • 19
      Yeah, I run 91 already and a few days prior I changed the plugs. Thanks
      '14 S4
      '04 M3
      '79 911SC
      • Jean
        • 18228
        You might get lucky.
        • Eurospec
          • 2612
          Hey Anthony,
          You could also try a fuel additive like techron or BG44k before you go for your retest. This along with a nice highway run will probably do the trick.
