Big time misfiring and no error code, I need help.
  • robbieosterman
    • May 2004
    • 199
  • nickmp0wer
    • 1427
    is it a severe car jolting thing
    • M-technik-3
      • 18946
      Test your coil pack. One of the cylinders might not be firing and raw gas could be going out exhaust valve and igniting in the exhaust.
      • Fred
        • 659
        Exactly, that's why you have coil packs instead of a coil, distrubutor cap, distributor rotor, and ignition wires.
        '86 325 2.8i stroker - Arctic Blue
        '11 328i Sports Wagon - LeMans Blue
        Strictly Eta
        • M-technik-3
          • 18946
          Originally posted by robbieosterman
          Coil pack ... ? I have a distributor-less ignition.
          Ok my suggestion is to buy this
          and this because the late model cover the engine you have
          Next is to do some reading.
          • CC Rider
            • Nov 2004
            • 17
            Sounds like a vacuum leak Could be time for a tune up as bad plugs and wires can cause this problem. Start by putting new plugs in. I don’t understand what you mean by
            “When I pulled the plugs though, they were steaming (the engine was hot) and it had a clear liquid on it ...” What had a clear liquid on it?
            1991 325ic Auto
            • UNHCLL
              • 8790
              Dont be a jack ass.
              It is a valid suggestion to buy Bentleys. Then you'd have known from the start you have coil-packs.
              If you get mad at the people who are trying to help you...
              Check your vaccum line to see if while under acceleration it is getitng pinched/pulled this will cause similar problems.
              Below the radar...
              • M-technik-3
                • 18946
                Exactly, it's called teminology. I gave you a very valid first place to start for a back fire for this type ignition.
                • M-technik-3
                  • 18946
                  Thanks for your help ... somehow I fixed it, I sanded off the crud on the spark plugs and threaded them back in, I retarded my advanced valve timing, and I fixed a semi-loose vacuum hose that looked like it might have been able to pop off while driving, and I replaced the alternator today. No problems thus far.
                  Would you care to elborate what how you retarded your advanced valve timing? The ECM controls both the M42 and M44 Ignition timing and is not adjustable. They are also not vanos controlled. So how did you retard the cams. Do you have adjustable timing gears?
                  So me sounds as though you had some bad plugs and or a loose vacuum line.
                  • M-technik-3
                    • 18946
                    First I didn't know they were adjustable but according to the manual you need some special tools and which are not cheap. How did you advance the timing? just loosen the intake gear and turn it? Did you now the settings that you were using? did you mess with the exhaust side at all.
