Hood problems
  • chase
    • 90
    Hood problems
    Yea, my hook wont latch. I went to put oil in, and i was having trouble getting the latch to pop, but i evtually pulled hard enough and it opened, but when i went to close it, the latch no longer latches...so currently its tied with a coat hanger.
    what can i do? this can't stay like this!!!
  • capnamerica
    • 14
    i had the same problem, i just had to bend the hook a lil bit towards the passenger side of the car. of course this might not be the same problem, my hood was off my car for several months and i assume the hook got bent sometime throughout this time
    • Vass325es
      • 252
      Sound like the hood's cable has been strench and need to adjust again nor buy new cable?
      1987 325es. LSD 3.25 (Stock)
      1984 325e (shell)
      Goal Project:
      5 Lugs Suspension
      1996 M3 S52
      E36 6 Speed
      Rieger/Mtech Body Kits
      Z3 Steering Rack
      • chase
        • 90
        thanks
        i think i'm going with your answer Vass. Are they hard to install? i can't even get my hand into the area in which the cable attaches to the latch area.
        thanks again
        • e30evolution
          West Werks
          • 1888
          hood cable being stretched would not explain the hood not latching.... look at the lastch and see if it is stuck... if not, the hooks the hood goes into are slightly bent... that would make it hard for the hood to pop, and very difficult to close it
          http://www.westwerksauto.com
          • Chapel
            • 633
            mine wont pop... Im hoping I can adjust the cable on the lever arm....
            BattleWagon|1996 GT Vertigo
            • Jordan
              • 12907
              The spring inside the hood latch catch snapped. Remove it and replace.
              https://mtechniqueabs.com/
              • Jordan
                • 12907
                No adjustments are offered on either end.
                • Jordan
                  • 12907
                  Just be like me. I broke the handle off the hood release cable (#2) so I completely removed it. Its a 2 second task to pop the hood with a flathead screwdriver, and it weighs less.
                  • Chapel
                    • 633
                    you talking about that 'external hood release' thingy next to the drivers headlamp?
                    Anyone have a good photo of where that is?
                    • boricuabimma'
                      • 566
                      I don't think that's a good Idea...
                      Not everyone reads with good intentions...
                      1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
                      • boricuabimma'
                        • 566
                        BTW I use too the screwdriver
                        it's not that hard
                        • el_4ever
                          • 145
