rocker shaft removal
  • dutchdude
    • Nov 2004
    • 6
    what do ya'll use to remove the rockershafts for replacement? like what do u use to drive them out, without damaging them?
  • rs4pro3
    • 5808
    I use a socket with the same outside diameter as the shafts and some long extensions, then hammer on the extension(i've got one mangled one to hammer on)
    85 325e 2.7 ITB'd stroker
    • cthulu703
      • Oct 2004
      • 288
      The rocker shafts should not be difficult to slide out, although mine were due to a warp in the head. I got mine out with a brass drift (always good to use a softer material than what you are hammering on), intending to replace the end caps. I then had the head annealed and pulled straight again.
      • Jordan
        • 12916
        Who the hell around here did that for you? Dan Hall?
        https://mtechniqueabs.com/
        • cthulu703
          • Oct 2004
          • 288
          Get out of my head!
          • Jordan
            • 12916
            lol. I will take that as a yes.
            • RedBaron86325
              • 386
              I've always used a wooden dowel and a rubber mallet. Cleaning the built up gunk on the shafts helps out a lot.
              Don't forget the good things Hitler did.
              • redbull 325is
                • 7471
                is the head still in the car or not?
                Julien
                Build Threads:
