Head bolts torque spec?
  • Kevan
    • Mar 2004
    • 25
    What do I torque the head bolts to?
    Thanks
  • arnoldgtr
    • Mar 2004
    • 153
    That would depend on which engine you have. M10 torque specs are different from M20.
    If you have an M20 with Torx head bolts, the torque spec is in three stages. On each stage, tighten all the head bolts in the proper sequence.
    Stage 1...22 ft-lbs
    Stage 2...90 degrees torque angle
    Stage 3...90 degrees torque angle
    John
    88 ///M3 Cinnabar
    84 318i Black
    • Kevan
      • Mar 2004
      • 25
      Oops forgot m20. Their 11mm head bolts and is there a conversion for degrees torque angle to ft-lbs.
      Thanks
      • nickmp0wer
        • 1427
        90 degrees is the amount u turn it lol like going from 12 to 3 on a clock
        • Jarvis
          • 2132
          Straight out of the Bentley:
          Tightening sequence (looking straight down to head, standing on exhaust side):
          12 10 4 2 6 8 14
          13 7 5 1 3 9 11
          Stage 1:
          Torx-head: 30Nm (22 ft. lb)
          Hex-head: 40 [+5/-0] Nm (30 [+4/-0] ft. lb)
          Stage 2:
          Torx-head: 90 deg.
          Hex-head: 60 [+5/-0] Nm (44 [+4/-0] ft. lb) after waiting 15 minutes
          Stage 3:
          Torx-head: 90 deg.
          Hex-head: 25 [+5/-0] deg. after running engine for 25 minutes
          -Jarvis, who was so bored that he went out to his car to get the Bentley and then type all of that for you.
          • Kevan
            • Mar 2004
            • 25
            Thanks for the help :D
            • Axxe
              • Aug 2004
              • 3355
              Every E30 owner should have a Bentley.
              Keep it slideways!!
