Crossed ignition wires
  • norwood e30
    • Mar 2007
    • 442
    A cuople of months ago i tried to change the spark plug wires. But i had installed them incorrectly so i hear a ping knock and back fire. Then i see a little smoke at the time as well. Now what damage did i do because after the issue the car never turned on after that. Help lol
    Crossed ignition wires should not result in damage to the engine. Once connected in the proper order the engine should run. So something else is probably the cause of the engine not running. A backfire could find a weak spot in one of the hoses that connect to the intake or even pop and injector seal. I'd suggest that you look for intake leaks.
    • norwood e30
      • Mar 2007
      • 442
      could i have cause a short in my electrical system.
        Not by just crossing ignition wires.
        • mcr_driver
          • 4491
          Something else is wrong
          crossing the wires probably caused a misfire the brought out the real issue?
          Do a check down of you engine see if anything is leaking etc
          • norwood e30
            • Mar 2007
            • 442
            No leaks as of right now. But the car had a lot of issues with the engine harness the car used to stall out the fuel pump relay used to go out time to time. the motor idle rough until you push on the accelerator. I have an other harness from my other car i crashed two years ago.
            • norwood e30
              • Mar 2007
              • 442
              I thought it was the ignition wires thats why i crossed them by accident lol. Anything else i should check for?
