Tachometer problem
  • Smatt90IS
    • 151
    Tachometer problem
    oaky i did a search and could not find the same problem every thing in my car works perfect execpt the tachometer i just had and electrical problem in my car i jumped the wrong pins i got that fixed to day :) all my fuses are good. The only thing i can think of is that i removed the speed sensor off the front of the engine and maybe i put it on wrong but i doubt it
    if you have ANY suggestions about getting the tach to work LMK it worked perfect before the pin incident the car runs like a bat out of hell if that makes a difference
    are there any relays that go to the tach
    I never took the cluster out BTW
  • ZM Blue Devil
    • Dec 2006
    • 13836
    si board?
    Levent
    %20levent@gutenparts.com
    Ladies:
    • Smatt90IS
      • 151
      maybe does that just die because it worked before the short? every thing else works ecept the econ and tach? ill check it out i apreciate the input
      • Jean
        • 18228
        "i jumped the wrong pins i got that fixed to day all my fuses are good. The only thing i can think of is that i removed the speed sensor off the front of the engine and maybe i put it on wrong but i doubt it "
        What pins did you jumper exactly? Speed sensor is in the diff at the back of the car. What did you remove?
        • iX-treame
          • 440
          It was the crank postion/speed sensor. And it was pins 19 & 17.
          '88 325iX -Totaled
          '97 M3 - Sold
          '85 euro e30 Pete McHenry 2.8L m20 Stroker - Parting out
          '89 325is - Sold
          '95 540i 6spd
          '87 325is M Technic I s50
            • 34839
            there are no sensors in the engine bay that send a signal to the tach - at least not directly. if something in there wasn't hooked up your engine wouldn't run. the tach signal comes from the ECU.
            • iX-treame
              • 440
              Yea we ran a few different ECUs, maybe it's the SI board.
              '88 325iX -Totaled
              '97 M3 - Sold
              '89 325is - Sold
              '95 540i 6spd
              • Smatt90IS
                • 151
                im going to try a differnt cluster soon
                • 325islovE
                  • Feb 2007
                  • 133
                  any updates my car is doing the same thing
                  1988 325is alpine
                  1989 325is zinno RIP
                  1992 325ic alpine
                  1986 325e cirrusblau
                  • clavinZERO
                    Hella sick E30
                    • Mar 2004
                    • 2027
                    is fuse #21 blown?
                    "BMW Style 32 Poster-Child"
                    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                    • bmws50b30
                      • Aug 2005
                      • 1151
                      Originally posted by ZM Blue Devil
                      si board?
                      this! i have the exact same problem. everything works except for the tach. sometimes it would work and then just die while driving. i replaced the SI board and it now works.
                      i guess it drained my battery quick since i never reset my service lights, it was always on.
                      1991 330is
