car wont start
  • ploobIX88
    • 31
    car wont start
    I was driving down a dirt road the other day and I hit a pretty big pothole that I didn't see in front of me. Afterr I hit it my car just died on me and now it won't start up. I haven't really had a chance to look at it yet but I'm thinking its not getting spark. So maybe the crank position sensor or something tied into that? Has this ever happened to anybody or could anybody givve me some advice as to what I should check for. Any help would be appreciated. Its an 88 325ix by the way if that makes any difference.
    Thanks,
    Brandon
  • ben312
    • Jan 2009
    • 1139
    make sure you have good connections everywhere, pretty easy to pop a wire out of place. if you have a multimeter check the igition coil. if you have 12v there but no spark its most likely a bad connection
    Originally posted by Beej '86 325es
    every time an M-tech 1 spoiler is destroyed, a baby seal dies.
    Originally posted by Jparkr
    The last thing we need are more of the retards on here thinking they are engineers too.
    87 325:83 jetta coupe:99 volvo c70:99 volvo s70
    • Philo
      Ich esse kleine Kinder
      • 3334
      Tons of things could have happened. You need to do some looking around and post some more info.
      Do lights come on? Does the car turn over? It could be something as simple as the ground or positive terminal popping off the battery.
      -tim
      Originally posted by Jordan
      I like the stance
      • ploobIX88
        • 31
        The lights come on and the car does turn over... all the accessories in the car still work like the radio and the windows... the car just won't actually start.
        • Philo
          • 3334
          A quick test for fuel will help. Pull the line at the rail; turn over car; see if gas comes out. That is where I would start. It is simple, takes literally a minute, and covers half of the no start issue.
          -tim
          I like the stance
          • ben312
            • Jan 2009
            • 1139
            Check for fuel and spark. Knowing what your missing cuts what to look for in half.
            • Philo
              • 3334
              Do I hear an echo?
              -tim
              I like the stance
              • Yogawrench
                • Jul 2009
                • 115
                Check the negative ground connection to the oil pan. You could have popped that loose when you hit the pothole. The car perhaps has enough other grounded points to run lights/accessories but I'm not sure the car will start w/o the ground to the oil pan.
                1993 Alpine White II 325i convertible (last year of E30 production)
                1988 Zinnoberot 325 Super ETA coupe
                • ploobIX88
                  • 31
                  Checked for fuel last night. Pulled the line to the fuel rail and no fuel came out. If it was a bad ground to the oil pan would that cause the whole issue?
                  • Philo
                    • 3334
                    No don't listen to that.
                    Now there is a wide range of things to test and check. Make sure your fuses are all good and plugged in (this is a given). Then using a fused jumper wire test the fuel pump at the relay to make sure the pump works. If it runs, then you move on to testing the crank positioning sensor with a multi-meter. If that is also good, then there are 2 possibilities: DME or a bad relay. Both of these problems are diagnosed by switching each item out, one at a time, with a known good part.
                    -tim
                    I like the stance
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      tried wiggling the relay connections? the main relay is tied into the fuel pump relay it suppllies power to it also supplies power to the ign. coil. wiggle both of em could just be loose there from the bump.
                      '89 Alpine S52 with goodies
                      • ploobIX88
                        • 31
                        alright i will be checking all that tomorrow and i will let you guys know what i find out... i was thinking that it could be the inertia switch or fuel cut off switch. but im not even sure that my car has one. does anybody know if my car would have that and if it did would that explain any of my problems?
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          wtf are those no and no an e30 has neither, the bump you hit knocked something electrical loose
                          • Philo
                            • 3334
                            /\ This guy is god.
                            Anyhow, a similar "cut off" switch that the E30 has is the CPS. It is designed to turn on the fuel pump when the engine is cranking. Therefore, If you get in a wreck and the engine stops running, the CPS turns off the fuel pump.
                            -tim
                            I like the stance
                            • ploobIX88
                              • 31
                              would this CPS be something i should look into, i mean would that be something that could cause this sort of problem. and if so where would that be located?
