Now there is a wide range of things to test and check. Make sure your fuses are all good and plugged in (this is a given). Then using a fused jumper wire test the fuel pump at the relay to make sure the pump works. If it runs, then you move on to testing the crank positioning sensor with a multi-meter. If that is also good, then there are 2 possibilities: DME or a bad relay. Both of these problems are diagnosed by switching each item out, one at a time, with a known good part.
This is via my statement earlier. If you don't have a bentley repair manual you need one.
